July 19, 20224 yr First time post. The manual for this inverter says "recommended battery capacity" for number of parallel inverters 2 = 200AH 3 = 400AH 4 = 400AH 5 = 600AH 6 = 600AH I have 2 units in parallel and want to connect 2x 150ah (48V, 7,68kWh) batteries - any reason I shouldn't? Optionally I could get 2x 100ah (48V, 5,12kWh) Not sure if the manual is providing minimum recommended levels or actual values.
