July 29, 20224 yr Hi, I have a client currently that runs a business where he requires a 3 phase system that has a hydrolic press for hydrolic pypes and a tic welder. Will a Sunsink 8kva 3 phase do the job as I am worried it might overload as the hydrolic press utilizes a 4kva 3 phase motor and it pulls lots of current when it does the crimping. The tic welder is a small inverter type welder but not sure how the Sunsink will handle it. Anybody out there that can confirm if a sunsink can handle a inverter tic welder. Thanks in advance. M
July 29, 20224 yr 11 hours ago, MaDMaX said: Hi, I have a client currently that runs a business where he requires a 3 phase system that has a hydrolic press for hydrolic pypes and a tic welder. Will a Sunsink 8kva 3 phase do the job as I am worried it might overload as the hydrolic press utilizes a 4kva 3 phase motor and it pulls lots of current when it does the crimping. The tic welder is a small inverter type welder but not sure how the Sunsink will handle it. Anybody out there that can confirm if a sunsink can handle a inverter tic welder. Thanks in advance. M The 8kw is a single phase inverter. Perhaps take a look at the 3 phase 12kw that Sunsynk has.
