Infini Solar 10kW/48V Inverter
There is this fault 03 on 10kW48V infini solar inverter from Voltronic which I have been trying to know the cause of the failure parts. I was able to replace DCtoDC board and mainboard and the inverter works. Is there any expert that can give more explanation on the causes and best solution for the system.
Thank you
