September 19, 20223 yr Currently got 3 Pylontech US3000C setup with my interver and connected as per the Pylontech installation guide. Are there any advantages to connecting each battery negative and positive to a central busbar, and then onto the inverter?
September 19, 20223 yr I will only use a Busbar when you load is more than what the cables can handle. You can also double up on the cable from batt to inverter. If you have more than 1 inverter it can also help having a Busbar to connect the bank of batteries to multiple inverters.
