rct axpert mx2 8kva/8kw inverter + Greenrich u-p5000
Was anyone able to establish communication between this inverter and battery?
If I connect the LAN cable provided it gives error 61 when setting 5 is on Lib or Pyl.
Currently it is running fine when on USE with settings:
Bulk: 56v, Float: 54v, End: 48, Charge amp: 40a
Hi Marcel,
Keep the user settings, lots of ppl make a huge fuss about the Comms etc. With those user settings you have above that inverter will work very well with that battery. The Voltronics Inverter is a very smooth operator of a machine.
