September 28, 20223 yr Do have a Kodak OG5.48 inverter with Pylontech US2000 connected and working. Add a second battery Pylontech US2000C as master but communication with inverter does not take place. Could it be the communication cable between US2000C and inverter.
October 2, 20223 yr I have the “correct” cable supplied with the kit but it still produces a fault indicator on the master battery and a 06 fault on the inverter. Does anyone have the correct pin configuration for this cable?
October 2, 20223 yr 10 hours ago, John Brady said: 06 fault on the inverter. With an Axpert, fault code F06 means "output voltage too high", which is not related to battery BMS. Was that a typo, or did you perhaps mean warning ̣⚠code 06?
