September 29, 20223 yr Hi all i purchased a Deye 5kw inverter and currently looking just to subsidize my Eskom account. Batteries will be added at a later stage , i do have limited roof space and i am looking at 6x 540w Canadian Solar panels to start off with. will these panels be compatible ?
September 29, 20223 yr 7 hours ago, Shai said: Hi all i purchased a Deye 5kw inverter and currently looking just to subsidize my Eskom account. Batteries will be added at a later stage , i do have limited roof space and i am looking at 6x 540w Canadian Solar panels to start off with. will these panels be compatible ? The Deye 5k has 2 MPPT controllers. 1 string of 6 x 49.2V = 295.2V 2 strings of 3 x 49.2V = 147.6V - this is too low for the MPPT Just ensure you don't exceed the max Voltage per MPPT - 425Vd.c The below table is from SunSunk 5k, Deye should be the same:
October 11, 20223 yr Hi 👋 busy specking my solar panels. Did the math and im sure i can run 7 x 545w panels per mppt on deye 5kw. Thus 14 in total. The voltage per string is within mppt range. But according to an article i read, one can spec the voltage to the max pv input which is 500v?? yes i also compensated for temp drop lastly the deye is rated at 6500w max. Is that per mppt or in total? As 14 x 545w would exceed that Tx
October 12, 20223 yr 11 hours ago, Philly said: Hi 👋 busy specking my solar panels. Did the math and im sure i can run 7 x 545w panels per mppt on deye 5kw. Thus 14 in total. The voltage per string is within mppt range. But according to an article i read, one can spec the voltage to the max pv input which is 500v?? yes i also compensated for temp drop lastly the deye is rated at 6500w max. Is that per mppt or in total? As 14 x 545w would exceed that Tx 6500w is in total for the inverter - you CAN overspec this as you would get benefit in winter. What is the VOC of the panels? That VOC * number of panels per string should not exceed the mppt max input voltage (not the pv max voltage)
