Solar Panel Grounding String Configuration
I am implementing 10x JA Solar , 540W Panels with a Deye 8KW inverter.
The user manual for the Deye 8KW inverter , says do not ground the solar panels.
Can anyone advise on this , because the panels have grounding points and need to be grounded so I am conflicted , what should I do ?
Thank you P1000.
When grounding the Frame , i was thinking of grounding those to an earth spike ?
Should this be grounded to the house ground or will the earth spike be okay , please elaborate on the best way to ground the panels.
