October 26, 20223 yr Morning all, I recently bought the LuxPower SNA 5000 and Pylontech US3000C to use as a plug and play/UPS while I'm in an apartment with the thought of getting it set up properly next year in a house. The issue is as follows: I receive "Communication failure with battery" messages on the application. I have the correct CAN cable connected from the inverter to the CAN of the Pylontech. The cable is orientated correctly as shown in the photo below: The battery lights are not on, but periodically come on with the first light illuminated and the second light flashing before both turn off again. The run light is only active in this periodic occurrence. I am not sure what the problem is - I have tried to look for ways to set the communication to CAN but there is no such setting. All the relevant settings have been applied following the LuxPower YouTube video with Pylontech batteries. I've spoken to the supplier who says it's the wrong cable but as you can see above, it matches the manual correctly. I'm considering take the whole setup to them for assistance but just hoping someone here is more knowledgable and could help. Thank you
October 26, 20223 yr It looks like the pinout written on the inverter differs from what is in the manual: Also see this thread: You can get a cable here: https://www.inverter-warehouse.co.za/products/luxpower-to-pylontech-coms-cable Also note: try not to mix pairs, so use the blue pair, and change the pins on the other end (don't mix green/blue like in the linked thread). Edited October 26, 20223 yr by P1000
October 26, 20223 yr Author Thank you very much, I took the setup to Solar and Inverter Warhouse and they were able to make the correct cable. It's working as intended. Happy to delete the thread or leave it open in case anyone else has the issue. I did get a response from LuxPower support as well and have attached the updated document. Pin Defination for battery communication 2022-10-20.pdf
October 26, 20223 yr On the Hubble website Luxpower Inverter guide they actually have a bold Note about this that points out the two Pin out configurations used by Luxpower. PLEASE NOTE: Check both the user-manual and the packaging of your inverter for its CAN pinout! Some LuxPower units use pins 4 and 5, whereas others still use pins 3 and 4.
