November 12, 20223 yr Good day all On the Farm we have three 8kw Deye single phase inverters connected in parrallel on a three phase system. Can anyone assist me with details on how i can connect a 3phase 30Kva generator to the system to charge the bateries? Any help will be highly appreciated Thanks
November 12, 20223 yr 58 minutes ago, Gerrit1984 said: Can anyone assist me with details on how i can connect a 3phase 30Kva generator to the system to charge the bateries? Hi Gerrit, are your 3 inverters setup to a true 3-phase system (not in parallel)? If yes, the generator could be connected to the inverters AC input. Phase sequence must be respected. Otherwise you will need a 3-phase rectifier/charger, directly connected to the batteries.
November 21, 20223 yr Hi Gerrit I need to install 3 x 8kw inverters for a 3 phase system. would you mind sharing your configuration or wiring diagram?
