Help LuxPower Inverter Settings
Hi Guys, I've recently had a new installation done grid tied backup only. Could the more knowledgeable on this topic please help me with verifying if my settings are optimal relative to my configuration.
I am running:
X1 LUXPOWER 5.5KW HYBRID INVERTER
X2 SHOTO 5.12KWH LI-ION BATTERY
1 hour ago, Antonio de Sa said:
I don't know much about the Luxpower inverters, however, you have Li battery, and your setting says charge voltage (lead-Acid)
If you have no comms between battery and inverter, then you can use voltage based settings specific to your battery pack.
In OPs case, I see some cables running down to the inverter and between the packs, so he needs to check both his inverter and battery manuals to ensure the correct communication settings and the correct communication cable with the correct pinouts are being used
