January 10, 20233 yr Hi My name is Edu. I’m startibg with mi first installation with a goodwe invertee, model GoodWe5048Es and 14 panels 410W. I have a little problem with wifi interface. making infinite ping to ip, sometimes not responding. My lan is correct and wifi stable. This is normal?? thanks!! Edited January 10, 20233 yr by Edu4rd0
January 11, 20233 yr Hi @Edu4rd0 What firmware do you have installed? New ES Series Inverters have 2 different firmware installed (the Wi-Fi antenna has its own firmware). Goodwe calls one the DSP Firmware and the other the ARM Firmware. The ARM firmware is directly related to the WIFI errors of these inverters. CEF
January 11, 20233 yr Welcome to the forum. Enjoy your journey. Oh, and I agree with @Cef, first thing to do is check the firmware versions.
