January 11, 20233 yr Hi, I have for repair inverterEASUN iSolar SMR II 5.5kW ( REVO-VM II 5.5kW ). Inverter start, after few seconds no battery show on display and inverter not get power, no any error. I test with other controller board, work good, i think is firmware problem or microcontroller. First to change controller need to test with new firmware Edited January 11, 20233 yr by mihaigsm2003 Added foto
January 11, 20233 yr 1 hour ago, mihaigsm2003 said: EASUN iSolar SMR II 5.5kW 5.5 kW is a non-standard size for an Axpert. So this appears to be a clone, even though EASun appear to resell legitimate (non-clone) Voltronic inverters as well. Or maybe this is a clone manufacturer illegally using the EASun brand. In any case, I don't think that you can use standard Axpert firmware for these, unless 5.5 kW is a straight-out lie and it's actually an Axpert MKS II 5.0 kW.
