January 17, 20233 yr I am not knowledgeable about the topic, so I can really use your input. Our energy need is about 15kW per day I have to make a choice between the following two setups: 1. INVERTER INIFINI VII WP 6K ON-GRID IP65 with lithium battery 5,2kWh 48 Volt 100AH or 2. SUNSYNK 5K Hybrid PV Inverter 48V IP65 with Sunsynk Battery LFP Rack Mount 5.32kWh 51.2V All and all the Infini setup will be R17k cheaper but I don't want to be penny wise, pound foolish.
January 17, 20233 yr The Sunsynk combo will extend the warranty to 10 years which is a plus. I may be mistaken but the Infini units look like yet another Axpert which isnt entirely terrible, but its also not the same quality as Sunsynk.
January 17, 20233 yr 20 minutes ago, RocketBoy said: The Sunsynk combo will extend the warranty to 10 years which is a plus. I may be mistaken but the Infini units look like yet another Axpert which isnt entirely terrible, but its also not the same quality as Sunsynk. Not exactly. The Infini is not yet another Axpert. The original manufacturing company here is Voltronic Power, and they produce the original Axpert and Infini ranges of inverters, which I guess are then re-branded by any number of companies. But the functionality is definitely different, the Infini is a full hybrid inverter with features like grid exporting, and it is comparable to the Sunsynk. I'm not commenting on whether the Infinisolar is better or worse than the Sunsynk, just saying that the Infini is not just another Axpert rebrand or clone.
January 17, 20233 yr 5 hours ago, Adriana said: I am not knowledgeable about the topic, so I can really use your input. Our energy need is about 15kW per day I have to make a choice between the following two setups: 1. INVERTER INIFINI VII WP 6K ON-GRID IP65 with lithium battery 5,2kWh 48 Volt 100AH or 2. SUNSYNK 5K Hybrid PV Inverter 48V IP65 with Sunsynk Battery LFP Rack Mount 5.32kWh 51.2V All and all the Infini setup will be R17k cheaper but I don't want to be penny wise, pound foolish. Out of interest what is the line item pricing for the INIFINI VII WP 6K ?
January 17, 20233 yr Interesting. The first time ever I see "voltronicpower.com" at the bottom of a Inverter spec sheet. Have a look at the bottom left of the linked PDF. https://www.aksolartech.co.za/wp-content/uploads/2022/08/Infini-VII-WP_DS-1.pdf
January 17, 20233 yr Author 2 hours ago, LumexClipsal said: Out of interest what is the line item pricing for the INIFINI VII WP 6K ? 19
