Configuration for a MUST Inverter
Hello, I have a MUST 5KW inverter that seems to be indicating a wrong battery charge representation on the display parcel. How can I deal with this?
Also, the battery pack installed doesn't seem to have the MUST inverter selection in the CAN and RS485 connection modes so which one is optimal for communication between the battery and inverter?
On 2023/01/24 at 12:46 PM, roboza said:
Thank you for your input. I 100% agree with you on your interpretation however my inverter does not have the SUB option. Only the other 3 options.
neiher does mine, mine is a Navasolar 3kw, but PV priority seems to be a sub. The problem is when PV is low it uses battery ( I am sure of it). Then when solar vanishes you hear the A/C kick on and go crazy charging back up the batteries.
hello all,
i have a MUST 3KW 24 volt set up
im so frustrated
it won,t reset from utility to sol asa priority, even when i go to the SET and change from ntt to tst.
it always reverts back to utility and ntt
whats the point in having a solar system when its using the grid ? all the time
am I doing something wrong, the parameters willnot adjust
can someone advise please
  • 6 months later...
Good day ill probably be the first guy to ask a question like this, I'll take the criticism but correct me in this issue. I have more and mor clients ask me.
Can these hybrid system be run without cells? obviously this is regarding the installation not done correctly and the batteries are taking a beating from the demand
