January 23, 20233 yr Hi All Could someone please urgently assist me? It would be really appreciated. I have a 5kVa Luxpower inverter with 4 X 545W Solar panels and one 4.8kWh Dyness Battery. The battery charges perfectly fine with the inverter through the grid and the system works. However, the solar panels are not picking up at all. No voltages and currents are showing and it stays on 0 for those values for some reason . I've checked my separate DC connection breakers and it shows power is coming in from the solar but nothing is showing on the inverter and there are no faults as well. There is also line arrow showing the solar to the inverter when I enable PV. Thank you in advance. Regards
January 23, 20233 yr Have you measured the voltage of your solar panels at the MC4 connectors at the Inverter end?
May 17, 20233 yr On 2023/01/23 at 8:22 PM, Leeshan said: Hi All Could someone please urgently assist me? It would be really appreciated. I have a 5kVa Luxpower inverter with 4 X 545W Solar panels and one 4.8kWh Dyness Battery. The battery charges perfectly fine with the inverter through the grid and the system works. However, the solar panels are not picking up at all. No voltages and currents are showing and it stays on 0 for those values for some reason . I've checked my separate DC connection breakers and it shows power is coming in from the solar but nothing is showing on the inverter and there are no faults as well. There is also line arrow showing the solar to the inverter when I enable PV. Thank you in advance. Regards Did you manage to resolve this problem yet? I have the same problem with my new Lux inverter, but it’s winter now and my over panels are facing west. Not sure if this is why I’m not getting any charge from the panels at all?
May 4, 20242 yr I have the same problem. East and West orientation. No power being generted after 12h00. I suspect it's to do with the orientation and winter declination of the sun. The system works perfectly when it's sunny.
May 4, 20242 yr 2 hours ago, DavidP said: East and West orientation. No power being generted after 12h00 That doesn't make sense unless 1. Your west panels are totally shaded 2. Your west string connection is faulty. You would have some output after 12 from your east facing panels. 2 hours ago, DavidP said: The system works perfectly when it's sunny. Please elaborate on the above statement.
June 1, 20242 yr Anyone get this resolved , i have to restart my inverter for solar to produce SNA 5000 Leoch 48v 8 canadian 400w
