January 30, 20233 yr I have a Revov R100, which has a design lifespan of 7000 cycles, and warranty for 3500. Is there a way to view this cycle count? I can't find it on the battery's menu or my Deye inverter. It sounds like partial cycles are measured according to the capacity used, e.g. using 20% would count as 0.2 cycles. But I'd like to confirm this, so it would be useful to see the actual number of cycles. It looks like solar assistant might be able to get this info, but I don't want to spend over R3k just for those stats (Solarman + Home Assistant already works well for me).
January 30, 20233 yr Following… also have a deye with Pylon so keen to hear how to check the cycles. Thanks
January 30, 20233 yr Author Only saw this now: Looks like that should work with the cable from SolarAssistant. Not sure about the Pylon one though, that may use a different protocol.
January 31, 20233 yr Author So the cycle count is actually displayed on the battery's LCD - got the info from Revov's technical support: Analogue information -> Cell Capacity -> CC (cycle count). And it's nice to see it matches up nicely with the total battery discharge stats - in my case around 210-220kWh total discharge resulting in 43 cycles, for a 5kWh battery.
