February 4, 20233 yr Good afternoon everyone. I am going to buy a 5kVA hybrid inverter. I already have 6 x 480W panels, Voc: 49.92; Vmp: 41.76 Imp: 11.52 per panel. Does any of you have knowledge of the LVTOPSUN 5kVA inverter? I am on a budget of no mor than R12 000 and I can get this inverter for R10 000. Will appreciate your thought and experience. LVTOPSUN HF4850S80-H Datasheet.pdf
February 4, 20233 yr 2 hours ago, deonholt said: Good afternoon everyone. I am going to buy a 5kVA hybrid inverter. I already have 6 x 480W panels, Voc: 49.92; Vmp: 41.76 Imp: 11.52 per panel. Does any of you have knowledge of the LVTOPSUN 5kVA inverter? I am on a budget of no mor than R12 000 and I can get this inverter for R10 000. Will appreciate your thought and experience. LVTOPSUN HF4850S80-H Datasheet.pdf 1.42 MB · 0 downloads No experience with it but it has the typical Axpert/Kodak/Mecer high voltage solar controller. Panel will work well with it.
February 4, 20233 yr Author 1 hour ago, Scorp007 said: No experience with it but it has the typical Axpert/Kodak/Mecer high voltage solar controller. Panel will work well with it. Thanks. I appreciate your help.
February 4, 20233 yr @deonholt Just as additional info. For a bit more, the Esener Inverter, with local support may be another consideration. https://www.securityandmore.co.za/products/esener-5-5kw-inverter https://www.esener.co.za/index.html Edited February 4, 20233 yr by zsde
February 4, 20233 yr Author 23 minutes ago, zsde said: @deonholt Just as additional info. For a bit more, the Esener Inverter, with local support may be another consideration. https://www.securityandmore.co.za/products/esener-5-5kw-inverter https://www.esener.co.za/index.html Thanks so much. I will definitely consider it. I am trying to find a Growatt at a good price and will take the Esener as 2nd choice. Thanks again.
