February 5, 20233 yr Hi Guys, I got a very old house that has been build on to, and with two DBs that I not would like to split in essential and non essential if I can come away with it. I am busy installing a Sunsynk 8KW inverter with 2x Freedom won 5KW batteries. Got 20 x 360W panels in 2 strings that I used previously on a Grit tie system Is it possible to couple the one DB to the load and the other DB to the grid on the inverter, or must I go with the schlepp to re wire the DBs Thanks.
February 5, 20233 yr Hi Kraai a very old house come with very old wiring. It would be difficult to give any advice with no information. How is your load arranged in the 2 db. Send some pictures of the 2 db boards. With 8kw you could run all appliances if you manage it well so no need for essential and non essential. You could exclude the geyser and stove all depends on you.
