SunSynk grid output 440 volt
After topping up power from 0,00 our Sunsync inverter blew all the lights and some other stuff.
The output to the grid appears to be 440 volt! What’s going wrong here?
Hi Igor.
Are you measuring voltage on the load output or the grid input/output? If it’s on the grid side then that would mean a surge from Eskom. If on the load side then it’s possibly  an inverter fault.
