Overloading Inverter - what happens
Hey all,
In regards to a 8KW Deye Inverter, what would happen during non-loading shedding when excess load is pulled.
e.g. total 10KW
  • Geyser 3kw
  • Aircon 2kw
  • Kettle 1kw
  • hairdryer 2kw
  • other 3kw
 Would it bypass to make use of Eskom power or would something trip or would the house blow up :D
Thanks!
17 minutes ago, mzezman said:
8kw can passthrough to UPS / Essentials up to 11kw while eskom is around. If there is LS then it will trip at 8kw. That trip is also battery dependent - if you only have 1 0.5C battery then you are limited to that as well
Awesome, thank you very much for that!!
