February 25, 20233 yr Good morning i am relatively new to the Forum and Solar PV systems. I am not an electrician or PV technician. I have a Goodwe 5KV Inverter running on 23 panels. I had a problem with my batteries and a self proclaimed Techician came removed the batteries and changed settings on my PV master app. Sudddenly i am now feeding the grid 20 Units per day where i only used 1 Unit per day during day time. Is there anyone who can assist how to prevent the system of feeding into the Grid. I called Goodwe they recommended i must put export limit off then a day later they advise put the function on and put in 0 export limit and a Power factor of - 99. Now once again i am not a technician. The installer is of little to no use to me rumbling figures and he is to busy. Is there anyone who can guide me on what to do or provide a contact number of someone who can assist me. pv1.msg
February 25, 20233 yr This post was recognized by Energy-Jason! Bobster. was awarded the badge 'Great Support' and 25 points. Assuming it is a Goodwe ES Using PV Master or SolarGo 1) Advanced settings 2) Turn export power limitation ON 3) Set power limit to zero A small amount will still get sent back to grid (at least that;s the case with my Goodwe ES). I think that's the inverter trying to zero the meter for the day. Edited February 25, 20233 yr by Bobster.
March 11, 20233 yr Author Thnak you very much i reduced the Power factor to -99 and export Power Limitation to 0 and its sorted. Really appreciate the feedback.
March 14, 20233 yr On 11/3/2023 at 11:02, Jason77 said: Grazie mille, ho ridotto il fattore di potenza a -99 ed esportato la limitazione di potenza a 0 ed è stato risolto. Apprezzo molto il feedback. -99? Cosa cambia? Io ho impostato a 1.00
