Growatt Wifi Module - Unknow IP address
I am trying to get into the Growatt Wifi dongle's settings but I am not able to see its IP address on my network.
Online search says it is suppose to be 192.168.10.100 but that IP does not register on my Wifi. I have looked at all active IP's on my Wifi network and none registers to this dongle.
I successfully added the module to my Wifi using the Shine App but getting stuck here.
I had this. You need to login to the WiFi device(Data Logger) the WiFi code is 12345678.
When its joined you can access the IP address. Then manually configure your WiFi network on the device. Thereafter you can add it to the Shine app.
