Home Assistant plugin for TBB Inverter
I'm looking for a third party monitoring app like Home Assistant to integrate TBB inverter.
I have not seen any mention of TBB Inverter in any of such.  Not even Solar Assistant or ICC.
Will be grateful for any information.
They look like they might be Axpert clones. It would help to mention as many specifications as possible: e.g. 5 kW rated power, MPPT with 450 V max and 80 A charging current, etc. You might also try Watchpower (for Voltronic Axperts), even though you haven't paid for it by buying a Voltronic product. At least that will tell you whether it's Axpert compatible.
A photo, especially of the sticker on the side (if any) would also be very helpful.
1 hour ago, richtech said:
I'm not sure it's an Axpert Clone
No, definitely nothing like an Axpert, from your photos. Bidirectional presumably means grid interactive. The ratings imply that it has a 50 Hz transformer, which no Axperts or even Infinis have (to my knowledge). I was going on a small product photo from a quick search.
  • 5 months later...
I’m interest in getting a TBB RiiO inverter, but only if I can connect it to my Home Assistant. Any info on that one?
Anyone knows if TBB inverters expose some kind of API - REST or Modbus or something? If yes, writing a Home Assistant integration should be doable. I can’t find any API docs however.
  • 1 year later...
On 25.09.2023 at 21:26, Mike Pan said:
Я зацікавлений у придбанні інвертора TBB RiiO, але лише за умови, що я зможу підключити його до свого Домашнього Асистента. Є якась інформація про нього?
Хтось знає, чи інвертори TBB мають якийсь API — REST, Modbus чи щось подібне? Якщо так, то написання інтеграції Home Assistant має бути можливим. Однак я не можу знайти жодної документації API.
У вас получилось подключить инвертор tbbpower в homeassistant ? Я ни где не могу найти решения! Может вы что-то подскажите?
