March 12, 20233 yr Can anybody please help me with the pins lay-out of the communication cable between this type of battery (mine the FB-5100S supplied by First National Battery) and my Kodak OG-7.2kW inverter, or maybe direct me to where I can obtain one. Much appreciated
March 17, 20233 yr Considering that the battery runs CAN communication by default, the standard CAN RJ45 pinout should help? Inverter side would probably be T568-A and battery side T568-B. From CFE manual
June 28, 20233 yr FYI - Kodak OG-7.2kW and 5100S battery - did you get the communication working - as far as I know you will have to use it in voltage mode on any voltronic inverter
July 21, 20233 yr The RT5100S can communicate with POW-VM5K-111, Infinisolar series 48V,Axpert-King series 48V if the battery and inverter are all in the latest firmware
