March 13, 20233 yr Hi, What is the easiest / most effective way to compile own charts or editing existing ones? There are some charts where I want additional data on the chart and it doesn't seem possible to do. Downloading data, one by one, converting to numbers and making charts is not effective.
March 13, 20233 yr There currently isn't a way built into SA to do this - you would have to extract the data for each graph manually. If, however, you have SA integrated into Home Assistant then you could write the data from the MQTT messages into something like Graphana and manipulate it there
