Axpert Inveter and gel batteries.
I would like to know if Axpert inverters are compatible with batteries. I have gotten a good deal on a bunch of these but am not sure if Axpert understands and can handle them correctly.
HUH???
I guess the short answer is YES and NO... Axpert inverters are compatible with various types of batteries, but not all types of batteries...
Axpert inverters are available in a varying range, all of which require battery banks of either 24v or 48v (nominal) - the max power rating (Ah) of the connected bank would need to be carefully selected depending on the max grid charging current of the selected inverter if used as UPS type backup only, or the available PV overhead if charging via PV panels in an off-grid/grid-assist setup.
What batteries have you been offered and what would you like to accomplish?
