PV fuses based on STC or NOCT values?
I need to choose a fuse to use on my PV strings of 330W Japan Solar panels
@ STC
Short circuit current is 9.28A
Max Power current is 8.77A
@ NOCT
Short circuit current is 7.4A
Max Power current is 6.97A
Which value do I base my fuse requirements on? STC or NOCT values, and short circuit current or Max Power current?
If fuses are meant to be the current plus 25% it would be either a 12A or 10A, depending on which values I use?
So then does it work like so?
PV cable diameter          amp rating        PV fuse (amperage less 25%)
4mm                                     55A                               ~40A
6mm                                     70A                               ~50A
10mm                                   98A                               ~75A
9 hours ago, P1000 said:
Based on the cables used.
https://www.explorist.life/how-to-fuse-a-solar-panel-array-and-why-you-may-not-need-to/#:~:text=Each solar panel has a,What is this%3F&text=Since the Maximum Series Fuse,handle a max of 15A.
https://pqrs.co.za/solar-pv-fuse-considerations/
Upon further reading,  based on these two references, where in my case, my panels are all in series on a single string. I actually don't need a fuse. A fuse is only of value when you have number of strings in parallel, and IS based on the short circuit rating of the panel, and the number of strings in parallel.
the panel specs usually state rated fuse to to use.
just using your description i found specs for Japan Solar JPS-330P-72 (330W) solar panels, stating a 20amp fuse is required for series strings.
