March 16, 20233 yr Hello In my country, we have lots of felicity lithium batteries, they are quite good so far, but there is a problem with it, they are just a black box, you can't get any info about the batt status ( each cell voltage - life cycles..etc ) I would like to see a report about a battery, I contacted the felicity technical support but they refused to give me the program and said that it's for thier technicals only and not public, does anyone know what is the program? There are many other lithium batteries on the market like D.GRID and BLUEJOY and they provide you with this info easily
March 16, 20233 yr Contact Solar Assistant and see if they are busy yet with compatibility for Felicity batteries. They support a huge range of batteries and Inverters already and their software provides the data that you are after. https://solar-assistant.io/help/general/introduction [email protected]
March 16, 20233 yr Author 4 hours ago, zsde said: Contact Solar Assistant and see if they are busy yet with compatibility for Felicity batteries. They support a huge range of batteries and Inverters already and their software provides the data that you are after. https://solar-assistant.io/help/general/introduction [email protected] All right, I will be in contact with them and ask, thank you so much
September 19, 20241 yr On 2023/03/16 at 1:42 PM, Taher Sylla said: All right, I will be in contact with them and ask, thank you so much Did you managed to monitor the Felicity cells ? for me I still can't find he converter and the cable in Damascus
September 19, 20241 yr You can monitor the battery via the correct cable and their battery upgrade software from your PC or Laptop. No need to update the battery first. The needed file is on the link too. EDMS battery monitor software https://www.felicitysolarsa.co.za/battery-upgrade Edited September 19, 20241 yr by zsde
September 19, 20241 yr Author 6 hours ago, esmail-kassir said: Did you managed to monitor the Felicity cells ? for me I still can't find he converter and the cable in Damascus Yes, you should find this usb converter in the market like bahsa, it is about 35000SP, I think I have another one if you want, I am in Ashrafiyat Sahnaya if you want, you can contact me on whatsapp : 00963983809945
September 19, 20241 yr 4 hours ago, Taher Sylla said: Yes, you should find this usb converter in the market like bahsa, it is about 35000SP, I think I have another one if you want, I am in Ashrafiyat Sahnaya if you want, you can contact me on whatsapp : 00963983809945 Sure , I will contact you soon thank you
