March 16, 20233 yr Hello, I have my system for 7 months now and my datalogger always just worked. Now suddenly it keeps loosing connection from my wifi. Can any one help me with this or must i replace it under warranty? Edited March 16, 20233 yr by Gman007
March 16, 20233 yr 48 minutes ago, Gman007 said: Hello, I have my system for 7 months now and my datalogger always just worked. Now suddenly it keeps loosing connection from my wifi. Can any one help me with this or must i replace it under warranty? Has anything changed in your wifi setup? New router or access point? Could you also check if there is a nearby AP broadcasting on the same frequency as yours? if so then you can change your frequency and see if that helps? 2.4ghz bands are very oversubscribed so lots of interference
March 17, 20233 yr Author Hello mzezman no wifi have changed, I checked the channels no issue there. We live far from other people so it should not interfere
March 31, 20233 yr Author I have found the problem, it was on my Wifi for some reason after firmware update on my router got more advanced setting for 2.4 wifi that did not work with the sunsynk dongle had to put wifi on Legacy for Legacy devices
