March 17, 20233 yr Hi all I just bought this 24v inverter i connected it up with 2 x 12v 100Ah batteries. Everything seems to be working fine. What confuses me is the fact that in its settings it displays the Charing,float voltages in 12v range. Is this correct? On its home screen it shows the batteries at 28v which is fine, im just worried that the batteries are not charing correctly. I would appreciate any feedback Regards Chris Edited March 17, 20233 yr by Chris Jensen
March 17, 20233 yr 1 hour ago, Chris Jensen said: Hi all I just bought this 24v inverter i connected it up with 2 x 12v 100Ah batteries. Everything seems to be working fine. What confuses me is the fact that in its settings it displays the Charing,float voltages in 12v range. Is this correct? On its home screen it shows the batteries at 28v which is fine, im just worried that the batteries are not charing correctly. I would appreciate any feedback Regards Chris It could be that the conversion for 12/24V is not done correctly and it displays per 12V battery in the settings screen. All settings should then be done at half than what you have. If all works well then all seems fine.
