March 26, 20233 yr 13 hours ago, Benji said: Where in Gauteng or Freestate can I get my Axpert 5kW inverter repaired? Hi @Benji what is the model, and what is the failure mode its exposing? Where are you located?
April 3, 20233 yr Author I'm in Bloemfontein. One morning during load shedding it just stopped working. No error message but the LCD flashed on and off and I could hear a relay switching on and off. The manual says a battery disconnect, but it was lead-acid batteries connected and voltage was above 50 volt. I charged them separately anyway and reconnect with the same result. Common sense tells me then there must be a internally disconnection from the battery. When I connect only the AC nothing happens - No lights, no sound. Any ideas?
