Help with Growatt 5000TL HVM
Good morning
Need some help to address the weirdest occurrence. Set up is 48v , 2x5kva Leoch LEFLI 48100 batteries and Growatt inverter. On the last 3 Monday mornings at approximately 3.30am, the system shuts down and we are not load shedding at the time. I reset the main battery, system powers up, state of charge on the batteries is full, except the final led says charging and inverter charge light flashes. Even during stage 6 load shedding,  the system performs like a champion so this shutdown is inexplicable
Really stumped and frustrated and hoping some forumites can point us in the right direction
Thank you all.
Haven't checked the load early hours of the morning, but only 2 fridges would drawing power then. When you say timer, are you referring to the inverter?
