April 12, 20233 yr Hello Hope all well! got a funny issue but we added PV to a growatt 5000 but in loadshedding times only the PV gets dropped and disconnected and then it starts up again to pulling 2000plus watts and charges battery and supplies load then it drops again. It does it all the time. anyone had this issue before or know of a solution perhaps ? many thanks !
April 12, 20233 yr Is your load constant at 2000wats plus or is there big fluctuation in loads I'm no pro at inverter but if there is big changes in loads then the mppt controller shuts down and remaps every time there is a big change in loads when running the load from solar .
