April 20, 20233 yr Hi all, I have a 3kVa FiveStar inverter and cannot seem to access the settings via the LCD display The manual says to press enter button for 3 seconds but nothing happens Anyone else come across this
April 21, 20233 yr 22 hours ago, PaulN said: Hi all, I have a 3kVa FiveStar inverter and cannot seem to access the settings via the LCD display The manual says to press enter button for 3 seconds but nothing happens Anyone else come across this When you press the enter key, it needs to make a loud beep sound, keep holding it down while beeping until it enters the settings menu, it will keep beeping, if the beeping stops then the button press is also stopped. So keep it in. Let us know.
April 21, 20233 yr Author 1 minute ago, Eurard said: When you press the enter key, it needs to make a loud beep sound, keep holding it down while beeping until it enters the settings menu, it will keep beeping, if the beeping stops then the button press is also stopped. So keep it in. Let us know. Hi, had to hold it for over 10 seconds before it went into the menu 00. Thanx for the input.
