April 27, 20233 yr Hi, When wiring the CT with the arrow pointing towards the Inverter Supply, I am getting a negative reading. I have flipped the Coil to get a positive reading What can I be doing wrong and should I be worried about it if receiving a positive value. Terminal 5 - White Terminal 6 - Black Any comment will be appreciated. Thank you Kind Regards Jason
April 27, 20233 yr Even the manual says if you get a negative reading, turn it the other way around / swap the white/black wires. So no issues with going against the arrow , as long as its working correctly.
