May 1, 20233 yr Hi, Installed new 5.6 with Dyness B3 all seems fine BMS data all fine...been through 2 loadshedding stages all good...only dropping 10% on battery and charging full again in 20 to 40min. But it seems like the fans are running full speed all the time...want to make sure there is not a setting set wrong somewhere. Bat type setting on Lic seems to give best info Any feedback will be appreciated Andy
May 1, 20233 yr 2 hours ago, Andy C said: But it seems like the fans are running full speed all the time...want to make sure there is not a setting set wrong somewhere. I'm pretty sure that there are no settings related to fan speed, and that they should not be running full speed all the time. What main (U1) firmware version are you running?
May 1, 20233 yr Author 1 hour ago, Coulomb said: I'm pretty sure that there are no settings related to fan speed, and that they should not be running full speed all the time. What main (U1) firmware version are you running? Currently 52.00
