May 1, 20233 yr When I set the time on my Deye inverter it keeps on resetting the time to one hour later. It stays correct for a few minutes then it jumps one hour forward on its own. Anyone who knows how to solve this? Edited May 1, 20233 yr by André Greyling
May 2, 20233 yr This is a temporary change though - ultimately you want to change the timezone that is used to Harare / Pretoria instead of Cairo. After that you should then be able to re-tick sync (if you so wish)
May 2, 20233 yr 53 minutes ago, mzezman said: This is a temporary change though - ultimately you want to change the timezone that is used to Harare / Pretoria instead of Cairo. After that you should then be able to re-tick sync (if you so wish) Thanks for the info. Yes Cairo is now +3 as they changed on 28-04.
