Battery setting for inverter when connecting 2 in series
I plan on connecting 2 lithium hubble s-100a 12v batteries in series to a 3kv 24v mecer inverter.
I have copied the below battery settings from the retailers website, and wanted to know if I should be doubling them as I am connecting the batteries in series to make a 24v bank.
Please note the bulk, float and cut-off voltages to be set for these batteries:
Bulk:14V
Float: 13.6V
Cut-off: 11.2V
Thanks for the help
Malcolm
Definitely yes.
You may check from time to time with a multimeter if both batteries have the same voltage. If there is a significant difference consult the seller.
