May 24, 20233 yr Hi everyone hope you guys are doing well with all that's going around the world. I got a question I want clarity on assuming that I got an 8kw Inverter with 2 5.5kwh lithium battery Using a 4mm AC cable to supply grid charge does this in any where affect the current with which the battery charges with let's 50Amps since it's using a small cable
May 24, 20233 yr 34 minutes ago, Taps said: Hi everyone hope you guys are doing well with all that's going around the world. I got a question I want clarity on assuming that I got an 8kw Inverter with 2 5.5kwh lithium battery Using a 4mm AC cable to supply grid charge does this in any where affect the current with which the battery charges with let's 50Amps since it's using a small cable No it won't affect the charging but you don't use a cable that WILL overheat when you draw up to 53A when the inverter is on bypass.
