Advice on a Hybrid Inverter.
I'm hoping to install a battery system and would like advice on a Hybrid Inverter.
I'm looking to use the inverter to supply up to 3.8kW (G98 limit I think) with the rest being made up from the grid. When grid is lost, I still want the inverter to work so need an grid isolations device (automatic island mode isolator), any recommendations?
Is there anything I need to be aware of when the grid is lost as there will be higher power devices in circuit (electric shower, cooker etc). Anything I can do to mitigate this?
Can anyone suggest an N-E bond relay for use in islanding mode?
Hi MikeJ, welcome to the club.
Almost any off-grid inverter will do everything you expect. In particular the Voltronics rebrand have that N-E bonding built in. Read trough the forums, you will find lots of informations.
