Nutlang Posted June 2, 2023 Share Posted June 2, 2023 Hi Guys Totally a newbie here, so excuse my ignorance and stupidy beforehand I bought a 1500W Sun Magic inverter with internal charger connected to a 200a/h 12V Dsatk slim line Gel Battery..Suspect i will be paying "school fees" pretty soon on the battery.. Total cost around R5850.. I try and limit the DC voltage to not go below 12V as according to most this is when the battery is at 50% DOD ?; not sure.. My load connected to this is around 370W, consist of a 50" Samsung LED TV = 150W; soundbar @ 210W and then the router and fibre connection box... My question that I have is that on the inverter, when it cuts out, shows 14.2V, with my multi meter I get 12.8V on the battery... I suspect the multi meter would be more accurate ?? Thoughts ? Quote Link to comment Share on other sites More sharing options...
GMAC Posted June 4, 2023 Share Posted June 4, 2023 (edited) On 2023/06/02 at 10:44 AM, Nutlang said: Hi Guys Totally a newbie here, so excuse my ignorance and stupidy beforehand I bought a 1500W Sun Magic inverter with internal charger connected to a 200a/h 12V Dsatk slim line Gel Battery..Suspect i will be paying "school fees" pretty soon on the battery.. Total cost around R5850.. I try and limit the DC voltage to not go below 12V as according to most this is when the battery is at 50% DOD ?; not sure.. My load connected to this is around 370W, consist of a 50" Samsung LED TV = 150W; soundbar @ 210W and then the router and fibre connection box... My question that I have is that on the inverter, when it cuts out, shows 14.2V, with my multi meter I get 12.8V on the battery... I suspect the multi meter would be more accurate ?? Thoughts ? A lot of these inverters are not accurate so I would trust the multimeter but to be 100% comper your multimeter with and friend one . The 50% dod is resting volts and not load volts so depending on the average load you can set your cut of volts lower than the 50% resting volts . An safe resting volts should be around 12.1, if your resting volts is 12.8 then your soc is around 85% . Edited June 4, 2023 by GMAC Quote Link to comment Share on other sites More sharing options...
Nutlang Posted June 7, 2023 Author Share Posted June 7, 2023 Thx for the feedback and advice Much appreciated.. On 2023/06/04 at 7:44 PM, GMAC said: A lot of these inverters are not accurate so I would trust the multimeter but to be 100% comper your multimeter with and friend one . The 50% dod is resting volts and not load volts so depending on the average load you can set your cut of volts lower than the 50% resting volts . An safe resting volts should be around 12.1, if your resting volts is 12.8 then your soc is around 85% . Quote Link to comment Share on other sites More sharing options...
SolarDIY Posted June 14, 2023 Share Posted June 14, 2023 I would agree that the multimeter will be accurate so trust that. Nutlang 1 Quote Link to comment Share on other sites More sharing options...
