Deye 5Kw solar panel Questions
Hi all,
My sister was sold a Deye 5kw inverter and 8 X Canadian solar panels.
Reading about amps of panels I am worried that it could magic smoke something.
Nominal maximum power - (Pmax) 545W
Optimum operating voltage - (Vmp) - 41.5V
Optimum operating current - (lmp) 13.14A
Open current voltage - (Voc) 49.4V
Short circuit current - (lsc) 13.96A            Maximum system voltage - 1500V
Maximum series fuse rating - 25A
Thanks,
Kevin
Read my post to a similar question you posed yesterday
In your scenario, those 8 panels seem like the perfect pairing, assuming they’ll be connected in one string in series, facing one direction. Again, just divide the inverter’s max volt input by the panel’s VoC spec (or multiply your 8 strings by the VoC of a panel), and you have what seems like a great pairing well within the inverter’s spec.
Regarding the amps, should you go slightly over (per spec), then the inverter clips the current. I don’t think the panel spec poses any issue for your inverter but perhaps others can confirm.
Edited by Kalahari Cruiser
Thank you very much for the advice, it's super hard to understand as some suppliers say out right you will blow the inverter.
I will relay the information, need to research installers in CT, Jacobs bay area for installation around August.
