June 13, 20233 yr Kodak inverter connected to solar and 2x polytech 5000 battery When eskom goes if switch over nice . Problem when eskom comes back after load shed , the inverter switch , then after few min, show red circle and restart , does it 3 times , sometime 5 times, then only it run normal . What can be the reason for this incorrect settings ??
June 13, 20233 yr Author 1 minute ago, apdcentral said: Kodak inverter connected to solar and 2x polytech 5000 battery When eskom goes if switch over nice . Problem when eskom comes back after load shed , the inverter switch , then after few min, show red circle and restart , does it 3 times , sometime 5 times, then only it run normal . What can be the reason for this incorrect settings ?? How do you upgrade the software , do you need to upgrade software ?
