June 22, 20233 yr Good morning, We have two pv banks installed, one facing east and one west. The first set is working great, but after 13h00 when the second set needs to kick in, it only delivers a nominal load and starts pulling power from the batteries. Is there some setting on the inverter that we need to change. Regards
June 22, 20233 yr It's likely, but more information is needed. For a start, what inverter are you using? Once you identify the inverter, forumites who are familiar with that inverter are able to assist.
June 22, 20233 yr 3 hours ago, corned232 said: Good morning, We have two pv banks installed, one facing east and one west. The first set is working great, but after 13h00 when the second set needs to kick in, it only delivers a nominal load and starts pulling power from the batteries. Is there some setting on the inverter that we need to change. Regards Also provide how many panels and make and size for East and west strings. Also location=province or area.
June 22, 20233 yr 3 hours ago, corned232 said: Good morning, We have two pv banks installed, one facing east and one west. The first set is working great, but after 13h00 when the second set needs to kick in, it only delivers a nominal load and starts pulling power from the batteries. Is there some setting on the inverter that we need to change. Regards As you have posted 2 identical questions perhaps delete the one. It seems we are answering on either.
June 22, 20233 yr Author Hi, We have a three phase system, 3 x 5kv Sunsynk inverters. I will confirm the panels. Its 15 on each side. I think its 525, not sure about the make. Will confirm
June 22, 20233 yr Author 3 x Sunsynk 5kw inverter parralel for 3phase system. 30 x 550w solar panels. 6 string of 5 panels each. 2 strings per inverter. 5 facing east. 5 facing west per inverter. Gauteng
