July 1, 20233 yr Well with the electricity price increase today I changed the price in the sunsynk app and it has changed the value of electricity generated for previous months as well. Is there a way around this?
July 4, 20232 yr Ja that is just sloppy programming. They are probably not used to price increases as often as we are 🙂
July 4, 20232 yr 9 minutes ago, Superfly said: LOL programming these things are not as easy as you think.. in a PC environment we will write to a Json file as a database .. but with EEPROM it's now or never... However if they write to a server that's a different matter... I don't know the app.. so just guessing. The sunsynk dongle sends inverter IoT data to the cloud (probably using mqtt portocol) which is then persisted into a cloud database. The synsynk app and sunsynk web displays the cloud data. see https://sunsynk.net Nothing to do with EEPOM. Programming these cloud apps is easy. I wouldn't use json for the rate, just an SQL table. The issue is sloppy programmers only use a single Rands/kWh rate for all calculations. create table city_power_tariff( year_month date not null primary key, tariff numeric not null ); -- my average CoJ rate per month insert into city_power_tariff(year_month,tariff) values ('2021-07-01',2.33), ('2021-08-01',2.33), ('2021-09-01',2.33), ('2021-10-01',2.33), ('2021-11-01',2.33), ('2021-12-01',2.33), ('2022-01-01',2.33), ('2022-02-01',2.33), ('2022-03-01',2.33), ('2022-04-01',2.33), ('2022-05-01',2.33), ('2022-06-01',2.33), ('2022-07-01',2.50), ('2022-08-01',2.50), ('2022-09-01',2.50), ('2022-10-01',2.50), ('2022-12-01',2.50), ('2023-01-01',2.50), ('2023-02-01',2.50), ('2023-03-01',2.50), ('2023-04-01',2.50), ('2023-05-01',2.50), ('2023-06-01',2.50), ('2023-07-01',2.85) ; SELECT TO_CHAR(dt, 'Dy DD Mon') as "Period", pv_energy as "Solar in", load_energy as "Load out", grid_energy_in as "Grid in", self_energy as "Self_kWh", load_energy*tariff as "R Load", grid_energy_in*tariff as "R Grid", self_energy*tariff as "R Saved" FROM solar_assistant_day LEFT OUTER JOIN city_power_tariff ON date_trunc('month',solar_assistant_day.dt) = city_power_tariff.year_month WHERE $__timeFilter(dt) ORDER by dt desc Edited July 4, 20232 yr by system32
July 4, 20232 yr 34 minutes ago, Superfly said: LOL programming these things are not as easy as you think.. in a PC environment we will write to a Json file as a database .. but with EEPROM it's now or never... However if they write to a server that's a different matter... I don't know the app.. so just guessing. I am sure electricity price and daily usage statistics, and calculated costs are not written to EEPROM. That would be madness. It all goes to their cloud service and served up as a webapp.
July 4, 20232 yr 30 minutes ago, Superfly said: Yep SQL is much easier from a a Db point of view but Json is more than storage but also web (Javascript/jquery) services friendly.. but let's not get into that - but thanx for the link... I need to check that out more. I tend to use both JSON and SQL. I store the IoT data from tasmota and sunsynk into a postgresql database with a JSONB format: -- DDL for a tasmota IoT sensor for the geyser table CREATE TABLE IF NOT EXISTS tele_geyser_sensor( id integer PRIMARY KEY GENERATED ALWAYS AS IDENTITY NOT NULL tm timestamptz DEFAULT current_timestamp NOT NULL, payload JSONB NOT NULL); -- store the tasmota json payload here CREATE INDEX tele_geyser_sensor_tm_idx ON tele_geyser_sensor(tm); Then create a view to access the JSON as a table: -- PostgreSQL 14 and later allow accessing JSON elements using the [] operator -- you can also use the SQL '->' and '->>' operators CREATE VIEW tele_geyser_sensor_v AS SELECT tm, tm::date AS dt, payload['ENERGY']['Power']::numeric AS power, -- same as ((payload -> 'ENERGY'::text) ->> 'Power'::text)::numeric AS power payload['ENERGY']['Current']::numeric AS current, payload['ENERGY']['Voltage']::numeric AS voltage, payload['ENERGY']['Today']::numeric AS today, payload['ENERGY']['Yesterday']::numeric AS yesterday, payload['ENERGY']['Total']::numeric AS total FROM tele_geyser_sensor; Edited July 4, 20232 yr by system32
