July 4, 20232 yr Hi I have a kodak og7.2 with a dead lcd, the power button is still working. I have no idea if i can buy these lcd control unit loose in the country and where?
July 4, 20232 yr Good Day Frans The screen can potentially be woken up by an MCU firmware update. But to answer your question, Yes. We do have stock of the LCD control spares. The LCD board may need a firmware update to properly function in case it has an older firmware version. Usually indicated by an error Code 32 on the screen upon switching on. See attached application note on how to conduct a firmware update on your Kodak inverter with a link to the the latest Kodak Firmware versions. Let me know if this helps SR Application Note KODAK OG RANGE FIRMWARE UPDATE PROCEDURE (3).pdf
July 4, 20232 yr Author Thanks for all the replies, glad to see Segen are active on this form After posting this i did call the customer and he said that the lcd is working again! If it happens again i will try a firmware update
