Growatt SPF5000TL repair in Cape Town?
Hi Guys
Have a SPF5000TL which is not registering any PV input. Has been running for about 3years without issues and now just dropped PV. Have restarted and reset without any luck, so suspect MPPT issue. Have 130v at the breaker coming in from PV panels.
Any suggestions on inverter repair in CPT? Ideal would be someone to disconnect, remove, repair and re-install.
Thanks!
Thanks, Did speak to GC Solar and Solarway as per Growatt support, but they only work on the items if it was bought from them.
Will contact Growatt SA directly.
