Koos Uys
1. What must the different current settings be when connecting 2 Luxpower SNA5000 inverters connected to 2 Shoto SDC-10 Box 5 batteries in parallel.
2. How many RCA485 communication cable must be connected between the 2 inverters?
3. Is only 1 CAN connection between the battery bank and the inverters necessary and to which inverter does it have to be connected?
LUX-POWER-BMS-com-with-SHOTO.pdf
ACS-Parallel-Connection.pdf
