DEYE 8KW INVERTER AND DYNESS 5.12KW BATTERY
GOOD DAY
I WOULD APPRECIATE ANY HELP AND ADVICE REGARDING THE FOLLOWING:-
I HAVE AN 8KW DEYE INVERTER WITH 8* 550W CANADIAN SOLAR PANELS ON 1 STRING LINKED VIA PV COMBINER BOV WHICH HAS FUSES FOR +VE AND -VE SOLAR CABLE, SPD AND BREAKER. 6MM SOLAR CABLE. AC PROTECTION INCLUDES SPD, MANUAL CHANGEOVER SWITCH, SEPARATE BREAKER FOR INVERTER AND ALSO 1 FOR ESKOM. I HAVE 150 AMP BATTERY DISCONNECT CONNECTED TO THE 5.12KW DYNESS BATTERY.
MY DB BOARD IS SPLIT INTO ESSENTIAL AND NON-ESSENTIAL LOADS
ESSENTIAL HAS MY PLUGS, LIGHTS AND BOREHOLE PUMP
NON-ESSENTIAL HAS MY GEYSER, STOVE AND OVEN.
ISSUE IS THAT OVER ABOUT THE PERIOD OF 1 MONTH THE SYSTEM HAS GONE INTO A FAULT MODE FOR  A FEW MINUTES AND THEN RESTARTS AGAIN AND WORKS NORMALLY. THIS HAPPENS EVEN WHEN MY USAGE IS RELATIVELY LOW.
ERROR MESSAGE F56DC_VOLT LOW, ANY IDEA WHY THIS COULD BE HAPPENING, AND ADVISE ON SOLUTION.
